Intelligent Tester2 for Toyota
Toyota Intelligent Tester2 with Oscilloscope fucntion, first grade touch screen, with safe box.
FUNCTION
All type of Toyota(made after 2000) and Lexus included read code, clear code, data flow, action testing and guard against theft initialization function. And it also supports OBD-II.
DENSO Diagnostic Tester-2(DST-2) for Toyota & LEXUS enables you to diagnose control system for engines, ABS and airbag, even through CAN-diagnosis communication.
CAN communication Diagnosis DST-2 realizes more accurate diagnosis through CAN communication that speed is 50 times faster than conventional.
Easy operation on LCE display with touch panel 5.7 inch full color display with touch panel assists an easier operation
Voltmeter and Oscilloscope not only communication basis diagnosis (Diagnostic code, ECU data monitor, Active test), but also voltmeter and oscilloscope detect alteration in the electric signal to find out the troubling part.
Data recording to your PC saved data such as data-list can be downloaded to your PC
CHARACTER
1. Touchscreen & back lighting control
2. Easy & quick
3. User needn"t worry about the after service since factory has an open patio for maintenance.
Specification
Dimensions 145mm x 223mm x 71mm
Source voltage DC 10-32V
Power consumption normail: 7W(12VDC) charging: 10W(12VDC)
LCD Display 5.7 inch
Touch panel input: By finger or stylus pen
Key four(up, down, two function keys)
Built-in clock for a time stamp
PC communication PC card slot CF x 1CH
USB Host: 1CH function: 1 CH
Serial 1CH ( RS-232C)
Vehicle communication CAN, ISO9141
Back up power supply lithium-ion battery 7.4V 1000mAh
PACKAGE LIST
1. Mainframe -- 1PC
2. OBD-II -- 1PC
3. Charging line -- 1PC
4. Lin line -- 1PC
5. Measuring leads for multimeter 1 -- 1PC
6. Measuring leads for multimeter 2 -- 1PC
AFTER SERVICE
1. Guarantee: One year, from the date equipment arrival
2. Upgrade free for one year
3. Upgrade method: CD
FAQ
Q: Is Toyota ITS2 with CF card?
A: Yes, Toyota IT2 is with CF card, there is a CF card slot at the back of Toyota IT2 main unit. When you use the main unit, please do not take it off, CF card is used to store the tested result. Please refer "Toyota ITS2 Names of the Parts".
Q: Is this new and with the oscilloscope too?
A: Yes, it is with oscilloscope.
Q: Can I use this product to do airbag coding?
A: Yes, you can. It can do airbag coding and simple ECU programming.
MSN: autolsale002@hotmail.com
Skype : autolsale002
Yahoo: autoltech@yahoo.com
FUNCTION
CHARACTER
2. Easy & quick
Specification
PACKAGE LIST
1. Mainframe -- 1PC
2. OBD-II -- 1PC
4. Lin line -- 1PC
AFTER SERVICE
FAQ
LAUNCH MD4MyCar
MD4MyCar is plug and play device which allows you to wirelessly connect your vehicle’s onboard computer to your iPhone or ipod touch.
It can be used to diagnose all the vehicles compatible via OBDII.
The product is suitable for the vehicles that supporting OBDII/EOBD protocols
MD4MyCar is the perfect companion for your iPhone and the best choice for the car lovers!
Danae:
MSN:autolsale002@hotmail.com
Skype: autolsale002
Danae:
Skype: autolsale002
While this subject can be very touchy for most peoplesantak ups price in Pakistan, my opinion is that there has to be a middle or common ground that we all can find.
apc ups price in PakistanI do appreciate that youve added relevant and intelligent commentary here though. Thank you!
Then after I shut it down it wouldn't come back on. When I would turn the key the digital display didn't even turn on. I talked to someone that had the same problem, and he said that it's from either a relay going bad or some wiring harness getting corrosion. He said that it happened to his SV one time.
____________________
Complete SPHR Certification Training - Get SPHR Certified
Testking IT Certification Prep, 100% Guaranteed Pass - Test-king.com
Welcome to Keiser University | Universities in Florida
Pittsburg State University - Wikipedia, the free encyclopedia
esldomino
02-27-2015 07:35 PM
plum
07-03-2013 04:16 AM
