Gas tank sticker
Old 04-13-2015, 09:13 AM
AlaskaSET's Avatar
Default Gas tank sticker
Hi,
I have a new C50T and can't seem to get the sticker on the tank to come off. Any suggestions on what might work?
Thanks!
Old 10-16-2016, 09:43 AM
Tazshido's Avatar
Go to the car parts place or wal-mart and buy a product called GooGone. squirt some of that on the top side of the emblem so it can trickle down through the double sticky tape holding it on. You might have to reapply a couple times to loosen the adhesive enough. When you go to pull the emblem off be VERY careful and slow so as not to damage your paint. There will be residue on the paint that will have to be carefully cleaned and then you'll probably have to use a good polish to finish it off.
Old 03-19-2017, 10:20 AM
10-64's Avatar
WD-40, with a hair dryer on "low" just to heat it up enough to peel it off slowly. Just keep spraying the WD-40 under it. It will come off easily
Old 05-10-2017, 12:20 AM
kcbr63's Avatar
You can go to a napa or paint store and buy a pin stripe eraser .it goes in a drill and simply wipes the sticker off but leaves paint and clearcoats alone they are awsome it also rubs off two sided tape.
jd1005
12-13-2012 10:51 PM
susuki_s83
11-30-2009 11:50 AM
fly117th
11-19-2007 09:47 PM
lowpockets_44
06-13-2007 09:43 AM
gavan7503
01-17-2007 04:50 AM
Quick Reply: Gas tank sticker
