1400 Intruder
Old 08-17-2005, 07:50 PM
Rickw's Avatar
Default 1400 Intruder
94 1400 suzuki Intruder. 28000 miles. Started making some rattling noises while riding. Also noticed more vibration. Started missing. Changed plugs. Very black with carbon. Now misses very badly. Blows black soot out exhaust. Have I destroyed the engine.? I have been riding all summer in the mountains of west virginia. Lots of slow low RPMs.
Old 08-18-2005, 08:30 PM
Patrick's Avatar
Administrator
Default RE: 1400 Intruder
have you tried a compression test? anything unusual in the oil? very poor fuel mileage?
Old 09-28-2005, 09:58 PM
harry2005_S83's Avatar
Black soot out the pipes usually indicates a flooding carb, Would doubt you have a major engine problem.
Old 10-03-2005, 09:20 PM
Patrick's Avatar
Administrator
has the carb ever been serviced?
Old 12-18-2015, 08:12 PM
trackfodder's Avatar
Does anyone know what model year side covers will fit a 2004 vs1400glp?
  #6
Old 01-12-2016, 10:05 PM
Default I do
I am putting a mistreated 1991 1400 together and was told it was a 2004 (no title). The stuff including side covers fits my 91 that I ordered for an 04.
One exception is the throttle, which is single pull cable. That lack of updates is probably why they are losing market share.
  #7
Old 01-12-2016, 10:08 PM
Default I do
  #8
Old 01-19-2016, 06:59 PM
does anyone know why the horsepower of a 1991 model was 71 hp and later models 60 hp?
  #9
Old 05-11-2016, 05:40 PM
I am having Hell trying to get the wiring to work. When I turn the ignition on, pull the clutch. and push the start button, I get a lot of chatter from a hungry fuell pump but no starter. The solenoid is OK if I charge it with probes. I need to know where the compression release control box is located, It's a 1991 VS1400GLP
  #10
Old 06-03-2016, 10:37 PM
The clutch switch was faulty. Starter runs OK now. I was really worried when what I was told was the drain plug was dry as well as just a few ounces of dirty oil came out when I changed the filter. salesman at a hardware store used to be a Suzuki dealer/mechanic and told me the drain on early ones (my 1991) was at the rear of the tranny. I got about a gallon of clean oil out of it. Refilled with 10W30 full synthetic. Got fed up trying to attach battery leads and brought battery home and secured the post nuts with Shoo Goo
Quick Reply: 1400 Intruder
