02 suzuki vs800 intruder.
Old 12-02-2016, 06:00 PM
Hopwood.justin's Avatar
Default 02 suzuki vs800 intruder.
So I am having troubles diagnosing why only my I'm running one cylinder.
I have power, the bike turns over and starts and the battery holds a charge. The fuel pump is working and all the lines are clear. Carburators seem to be working. Air filters are clean and I put new plugs. Also wires are fine, plugs both have spark. Can't figure out why I'm only running on the back cylinder though... help?
Old 02-01-2023, 12:13 PM
gb6906's Avatar
I have a question. How do you know it’s only running on one cylinder. I ask because being that it’s only a two cylinder engine if one’s not working I seriously doubt that it would run. Have you done a compression test? If you’re sure about the spark all you need is fuel and compression to make it run. I’d do the compression test first.
Jibber
08-05-2018 12:03 PM
Jibber
08-05-2018 12:02 PM
Lovettdc
06-27-2018 10:16 PM
cecarr08
03-15-2011 09:13 PM
hymn
07-25-2008 11:06 PM
Quick Reply: 02 suzuki vs800 intruder.
