Oil on spark plug? Need help
Old 03-01-2014, 09:00 PM
VanBeest's Avatar
Default Oil on spark plug? Need help
My reno stopped running. It'll turn over but won't fire. So I figured it was the fuel pump, so I went ahead and replaced that. Went to try and start it up but still nothing. Checked the spark plugs and #4 plug was covered in oil and could see oil in the cylinder. All the other cylinders and plugs are dry and normal. Could it be the piston rings? That's the first thing I thought, but I've heard valve cover gasket, valve stem tube, time chain, etc. so could you guys please help me out? Thanks!!
Old 04-29-2014, 09:19 PM
eyeclose's Avatar
Have a compression test. Oil in the plugs could indicate worn out rings or seals.
Old 04-25-2016, 11:08 PM
dodin04's Avatar
It's true, you only need to do what was said by @eyeclose and the problems that you ask to be completed with ease.
Sparkplugs.com
11-20-2012 12:34 AM
Sparkplugs.com
06-11-2007 12:39 PM
m_nourse
05-31-2007 02:34 PM
VOLXL7
06-16-2006 07:56 AM
chillinpapeSX
03-10-2006 01:09 PM
Quick Reply: Oil on spark plug? Need help
