2007 C90 Turn Signals
Can anyone tell me if a Right Rear Turn Signal Suzuki Part #35603-38AD0 is actually the same as Front Left Turn Signal Suzuki Part #35602-38AD0 even though they are different part numbers?
Hi Perk,
No, these two lights are different. The rear turn signals take 1156 single filament bulbs, and are 2 wire lights (only turn on for directional signal). The front turn signals take 1157 dual filament bulbs, and are 3 wire lights (directional signal AND running lights) That being said, I think the last time I had them off my bike they looked the same in appearance and mounting. I think you could probably use the front left on the rear right and only use 2 of the 3 wires (you will still need a 1157 bulb, the 1156 will not fit in the bulb holder) but not the rear light on the front. However, I have not actually tried this. Anyone? -MrN 2007 C90T |
Turn signals
Originally Posted by perk_dp
(Post 18857)
Rear and front signals
I want to have rear running light on my C90T stock lights are on bike and I wanted to try putting same lights from front on rear but is not wired for three wires in rear ,,so I could have running lights on rear as well I know I will have to run an additional hot wire for run where to I run wire from fuse box r what??
