Blown Fuse Problem
Old 07-16-2008, 10:11 PM
POMO Biker's Avatar
Default Blown Fuse Problem
My 10 AMP signal fuse keeps blowing. I end up losing the Speedometer, digital readout and the horn only - all my signal lights are working. After testing the possibilites of what might be causing this problem - I have discovered that when I turn the handlebars to the left the fuse blows. If I keep the handlebars straight then all is good. Anyone had trouble with this before?
Old 12-30-2009, 02:24 PM
2007 Boulevard C90's Avatar
Did this ever get resolved for you? I have a similar issue but the fuse that is blowing the main fuse which shuts down everything.
Old 10-16-2017, 11:26 AM
crazypilot18's Avatar
hello how did you fix it or found the issue making this fuse to blow
Old 10-17-2017, 11:27 AM
After three months of it sitting in the repair shop, two attorneys, and one visit from a Suzuki pro mechanic, they finally replaced the entire wiring harness from the fuse through the valve that relieves the cylinder pressure. Rode it for several years after that with no issues. Note. I was still under warranty!!! Still needed attorneys and lemon law protections. I'll never own another Suzuki after that experience. I was ok with the problem. But the treatment was terrible. Especially if it ever happened while I was riding at night!! Thank God it didn't. Only when starting and before it barely turned the motor over.
Old 10-17-2017, 11:35 AM
Check the wiring atthe handbar and under the tank pussible making contact with ground some wiires may be broken due to turns and vibrations
akc9063
03-16-2015 06:04 AM
bradley1
09-29-2008 03:24 AM
t47una
09-12-2008 07:29 PM
johnnguyen
11-09-2007 11:37 AM
deerslayer
08-08-2006 12:52 PM
Quick Reply: Blown Fuse Problem
