c50 blinker relay HELP!!!
I just got an aftermarket rear tailight/rear blinker for my '06 c50 . It came with an updated blinker relay(heavy duty) and needs to be swapped with the original blinker relay. I looked under the seat , under the battery box, in the headlight shell, and under the speedo. WHERE THE HECK IS THE BLINKER RELAY!!!!!
Can anyone here help a brotha out? thanks in advance. Chris Startt Easton MD |
RE: c50 blinker relay HELP!!!
Maybe left side chrome area where the fuse box is?
not there either...I just looked there.
I'm thinking under the black plastic cover, where the ignition is. the only place I haven't looked yet. is there a way to get it off without removal of the gastank? |
There are several wire bundles which are tied together inside the back of the headlight bowl. 2 phillips screws and the front of the headlight comes off. I think there may be a relay in there, but not sure.
Let us know what you find. Edmo |
