C50 wont start
my 2006 C50 suddenly died last night as I pulled up to the house. When I tried to start it today, the dash lights come on, but the injection doesnt power up and as a result the bike wont start. Any ideas?
It's probably unlikely, but have you checked your fuses? You also might ask the suzuki mechanics online. Cost for an answer is $9-22 but they'll give you a list of possibilities. You also could check on volusiariders.com to see if they have any threads.
yes, I pulled the relay cover off and checked the 2 30 amp fuses there, they were both good....suspecting now that the fuel pump is toast, seeing as how it just died the night before just as I finished a ride. I couldnt find any more fuses other than the 2 at the relay, so if there is a fuse panel, it is very well hidden
sorry, my bad. It's been a while since I accessed the fuses, and I was doing multiple things at the time. Main fuse should be under the front seat (according to the manual). The other fuses are behind the left crankcase cover (next to the lock box), Hope this helps.
