-   -   C50 wont start (https://suzukiforum.com/forum/boulevard-c90-boulevard-c50-16/c50-wont-start-2033/)
scotts Apr 10, 2009 02:54 PM
C50 wont start
my 2006 C50 suddenly died last night as I pulled up to the house. When I tried to start it today, the dash lights come on, but the injection doesnt power up and as a result the bike wont start. Any ideas?
vikingpnut Apr 11, 2009 02:37 AM
It's probably unlikely, but have you checked your fuses? You also might ask the suzuki mechanics online. Cost for an answer is $9-22 but they'll give you a list of possibilities. You also could check on volusiariders.com to see if they have any threads.
scotts Apr 11, 2009 05:34 AM
yes, I pulled the relay cover off and checked the 2 30 amp fuses there, they were both good....suspecting now that the fuel pump is toast, seeing as how it just died the night before just as I finished a ride. I couldnt find any more fuses other than the 2 at the relay, so if there is a fuse panel, it is very well hidden
vikingpnut Apr 11, 2009 03:51 PM
open up the lock box, remove the inner box, you should see a fuse box. How many miles on your c50? My m50 has 9500, no fuel injection issues.
scotts Apr 11, 2009 04:54 PM
about the same miles.....I figure a fuse is the only possibility
scotts Apr 11, 2009 05:07 PM
removed the toolbox behind the lock, no fuse panel...jeez?!?!?!
vikingpnut Apr 12, 2009 04:41 PM
sorry, my bad. It's been a while since I accessed the fuses, and I was doing multiple things at the time. Main fuse should be under the front seat (according to the manual). The other fuses are behind the left crankcase cover (next to the lock box), Hope this helps.
scotts Apr 12, 2009 08:32 PM
thanks....I did see what looked to be a wiring harness running behind the cover....will remove it and see what I see
scotts Apr 12, 2009 10:41 PM
Success!!!! one blown 15 amp ignition fuse...thanks for your help
