Changing the pipes
I'll be changing the pipes to Hard Kromes on Thursday. Anyone else out there with the same pipes? The dealer is recommending them; I hope I'm happy after spending this much right after buying the bike.
RE: Changing the pipes
i have an 05 c90 and installed a set of roadhouse duel pipes. one on either side under each bag. sounds and looks great, not cheap.
i had a set of hard krome stripper straights put on my 06 c90t they are loud , but a lot of back firing on decel, dealership says is because of the back pressure
macc1015, i also have a 2001 volucia and it backfired on decel. checked on the net and found that the pair valve that cycles the exhause back into the jugs causes the backfiring. Removed the pair valve and plugged the holes, no more backfiring. google "suzuki pairvalve" and view the response.
Did u get ur hard kromes , what do you think of them and how does your bike run , any backfiring ????????????????????
I ordered a set of Cobra slash downs on 07-05-06 to be here on 07-31-06. They did not arrive, was dold today they were on back order until 08-31-06. I ordered the Cobra Roadhouse pipes, should be here inthree days. Can't wait..
