Fuses in headlamp assembly
My light bar stopped working in my 2008 Suzuki C50 and I assume it must be a fuse. Anybody know if there is an inline fuse in one of the connectors inside the headlamp assembly? The only fuses in the owners manual are the main fuse and the accessory fuse (ground) at the battery. Both check out OK. Any ideas?
I also have a C50 and put an aftrmarket light bar on it, I don't recall any in line fuses. It sounds too simple but I'd check grounds and connections to ensure that they are all tight.
ChuckG Remember...Rubber Side down, Shiny Side up. |
aftermarket light bar
I have a 2005 boulevard c90t, and my light bar quit working, too. I have checked all connections upto and including the wires behind main headlight. I see no inline fuses.My lightbar has switch to turn the lights on and off. The switch is fine.
I am told there are only 2 fuses on this bike. Any suggestions? Fargo_mikeR |
