Battery???
Where is the battery on this bike? It's not under the seat like most bikes, huh? I think I see it on the very bottom, but have no clue as to how to get at it. I either need to change the battery or charge it.
It doesn't turn over and only makes a clicking noise when trying to start. I'm thinking the battery is close to dead and in need of a jump / charge or needs to be replaced. IS there anywhere on this site that could help with this? Also, does anyone know where to get a manual for the M50? Please help... |
http://www.motorcycle-journal.com/fo...tml#post480384 This guy puta m50 manual here, also some other tutorials. Should help you. Battery is sorta under the seat, you access it from the lock box. Open it remove the tools, then the inner box will come out and you have your fuses and battery. If you don't ride a lot all year i would suggest a trickle charger, some will come with leads you can attach to the battery terminal and run the leads out and out of sight, but easily accessible for charging.
its near the engine i think..
Motorbikes have strayed away from the use of traditional acid-filled battery power, many mature motorbikes still depend intensely on them.The process is not difficult, but it does require some focus to make sure that power supply will function as designed.
I am extremely impressed with your writing skills and also with the layout on your blog.
emerson ups price in Pakistan Is this a paid theme or did you customize it yourself? Either way keep up the nice quality writing,server rack price in Pakistanit’s rare to see a nice blog like this one these days |
| All times are GMT -5. The time now is 08:47 AM. |
