Need help with a 2006 M50
I finally found an 06 M50 for a good deal. Picked it up on Monday. THe only problem is it did not come with a manual. I was wondering if anybody could give me the spcs on Oil and FIlter for the 2006 M50 and also what has to be done in orde to adjust the rear shock (ie how do access it in order to adjust it).
Thanks in advance Justin |
RE: Need help with a 2006 M50
Have you found what you were looking for yet? I have an '08 but I imagine it would be the same since the bike hasn't changed much.
I'll find the answers for you tonight when I get home if you haven't heard anything. Jorge. |
jorgeh
Thank you for offering to look this up. I still do not have the information that I'm looking for. |
Justin,
Here is the information I found on the manual: Recommended engine oil is 10W-40 3.6 US qt. if filter is replaced. Filter part # is 16510-03G00 Again, this are for my 2008 model. Not sure if it's different from yours. The Pre-Load Adjustment is located behind the toolbox compartment. You need to actually remove the toolbox. Hope this helps, Jorge |
Thank you for all you help
