Suzuki Fault Codes
Old 05-01-2016, 01:29 AM
igor2009's Avatar
Default Suzuki Fault Codes
89–95 SIDEKICK & SAMURAI w/THROTTLE BODY INJECTION (TBI)
12 All Clear (No Fault Detected)
13 O2 Sensor circuit
14 Coolant Temperature Sensor Circuit
15 Coolant Temperature Sensor Circuit
21 Throttle Position Sensor Circuit
22 Throttle Position Sensor Circuit
23 Intake Air Temperature Sensor Circuit
24 Vehicle Speed Sensor Circuit
25 Intake Air Temperature Sensor Circuit
31 Atmospheric Pressure Sensor Circuit
32 Atmospheric Pressure Sensor Circuit
41 Ignition Signal Circuit
42 Crank Angle Sensor Circuit
44 Idle Switch Sensor Circuit
45 Idle Switch Sensor Circuit
51 EGR System & Recirculated Exhaust Gas Temperature Sensor
53 Ground Circuit
54 Fifth Gear Switch Circuit
71 Test Switch Circuit
ON ECM failure
92–95 SIDEKICK w/MULTI-POINT FUEL INJECTION (MPFI)
13 HO2S Circuit
14 ECT Sensor Circuit
15 ECT Sensor Circuit
21 TP Sensor Circuit
22 TP Sensor Circuit
23 IAT Sensor Circuit
24 VSS Circuit
25 Intake Air Sensor Circuit
33 Air Flow Sensor Circuit
34 Air Flow Sensor Circuit
42 CMP Sensor Circuit
44 Idle Switch Circuit
45 Idle Switch Circuit
51 EGR System & REGT Sensor Circuit
52 Fuel Injector
FULL List look at HERE Suzuki Fault Codes - car manuals & wiring diagrams
igor2009
05-01-2016 01:27 AM
esldomino
03-22-2015 10:26 PM
CCC3
10-15-2012 11:49 AM
blinton25
04-12-2007 04:43 PM
Neophyte
10-03-2005 09:22 PM
Quick Reply: Suzuki Fault Codes
