Problem with hot engine starting
I have a 95 sidekick 2wd/ I replaced the Injector which was not shutting off when the ignition was shut off. Now after the engine is run up to temperature and shut off it will restart bet not accelerate, just die if sped beyound an idel. After the engine cools all the way down it runs normal again. Any ideas would be appreciated.
