Suzuki Fault Codes
89–95 SIDEKICK & SAMURAI w/THROTTLE BODY INJECTION (TBI)
12 All Clear (No Fault Detected) 13 O2 Sensor circuit 14 Coolant Temperature Sensor Circuit 15 Coolant Temperature Sensor Circuit 21 Throttle Position Sensor Circuit 22 Throttle Position Sensor Circuit 23 Intake Air Temperature Sensor Circuit 24 Vehicle Speed Sensor Circuit 25 Intake Air Temperature Sensor Circuit 31 Atmospheric Pressure Sensor Circuit 32 Atmospheric Pressure Sensor Circuit 41 Ignition Signal Circuit 42 Crank Angle Sensor Circuit 44 Idle Switch Sensor Circuit 45 Idle Switch Sensor Circuit 51 EGR System & Recirculated Exhaust Gas Temperature Sensor 53 Ground Circuit 54 Fifth Gear Switch Circuit 71 Test Switch Circuit ON ECM failure 92–95 SIDEKICK w/MULTI-POINT FUEL INJECTION (MPFI) 13 HO2S Circuit 14 ECT Sensor Circuit 15 ECT Sensor Circuit 21 TP Sensor Circuit 22 TP Sensor Circuit 23 IAT Sensor Circuit 24 VSS Circuit 25 Intake Air Sensor Circuit 33 Air Flow Sensor Circuit 34 Air Flow Sensor Circuit 41 Ignition Signal Circuit 42 CMP Sensor Circuit 44 Idle Switch Circuit 45 Idle Switch Circuit 51 EGR System & REGT Sensor Circuit 52 Fuel Injector FULL List look at HERE Suzuki Fault Codes - car manuals & wiring diagrams |
