1978 TS 250 No Compression
Old Aug 22, 2011 | 04:59 PM
cowboykp's Avatar
Default 1978 TS 250 No Compression
I have a 1978 TS 250 and it stopped running. I have spark, and fuel, but no compression. Any ideas before I start tearing it apart?
Old Aug 26, 2011 | 02:08 PM
slicksuzukidave's Avatar
Default no compression?
have you checked under valve cover ? is the chain still connected? do valves still move up and down? have you taken plug out put finger in hole and kicked it? could be a couple of things relief valve could be stuck, or chain can be broke, or just rings wore out , i would try looking under valve cover first that will tell the tell . I know yeah duh but try the simplest first i don,t know if your mechanically inclined but try it and see . Hope i could help.
dimebag_from_hell
3
Dec 6, 2010 02:55 PM
Dr Egon
Jul 15, 2010 08:56 AM
jimcole198521
Jan 29, 2009 10:46 PM
recycle
600, 750
Oct 7, 2006 11:40 PM
gavan7503
Apr 23, 2006 04:13 AM
