Anyone have C90 electrical problems?
My Blvd has broken down on me 4 times...all electrical issues. It is a 2006 and mechanically...it runs great. It just keeps having electrical issues that leave me stranded on the road somewhere...Anyone else with similiar issues?!
RE: Anyone have C90 electrical problems?
YES, YES!! I too have been stranded. I have a 2005 c90t with only 1,545 miles that does not charge the battery properly. I realized the problem when I had the first check-up. The dealer says I need a stator so he ordered one. They are back ordered. He pulled the old one, I had it tested and the elec co says it is fine. Suzuki will not warrantee because of time.If you know anyone that is sharp that may have the anshis/her contact info will be appreciated. Thanks. gillis@ecc.edu Greg It is along story but I will detail it if you reply.
c90 electrical
I have a 2005 c90t and I have replace the stator twice in since 2005 and also the regulator/rectifier at the same time. I have also replace the battery 3 times. In September 2011 i had the stator and regulator/rectifier and battery changed. All was good for the first 40 miles then the bike died on the side of the road. No power or electrical. I had to get a boost to get the bike home. I am at a loss as to what might be causing the problem, anyone have any ideals?
PastorGumby
6
01-08-2009 04:17 PM
2005, 2007, alternator, boulevard, c90, c90t, c9o, charging, electrical, electricial, problem, problems, specifications, stator, suzuki, test
