Bike does not charge battery
Old Sep 19, 2008 | 07:02 AM
robinhood024's Avatar
Default Bike does not charge battery
I have a 05 boulivard C-90. I just bought a new battery and put on it,but after riding about 50 miles the battery goes completely dead ( like bike dies while riding down the road ).I checked the fuses and they were all ok. Doesanyone have an idea what might cause that ?
Old Sep 27, 2008 | 12:27 AM
BassCliff's Avatar
Default RE: Bike does not charge battery
Hi Mr. robinhood024,
I'm not really familiar with the charging systems on the newer bikes, but there are three basic components to the circuit. There's a stator (like an alternator, generating current/voltage), a regulator/rectifier (that turns AC into DC and regulates the voltage output), and the battery. Sometimes it's a simple as fixing a bad ground connection on the regulator/rectifier. Normally, if your system is overcharging, the r/r is bad. If your system is undercharging, the stator is bad. A bad r/r can ruin a stator if the r/r is not replaced quickly. There should be a troubleshooting procedure in your factory manual that will help you determine which component(s) is (are) bad. But first, check and clean all of the electrical connections, the fuse box too.
BassCliff
islander74
DR-Z400E, DR-Z250, DR-Z125L, DR-Z110, JR50
Apr 23, 2009 08:44 PM
fclark00
Nov 6, 2008 07:03 PM
wheeliethis
600, 750
Jul 3, 2007 11:32 AM
stefangsxr750
Apr 15, 2007 04:34 PM
