Bike Won't Turn Over
Old Aug 21, 2008 | 06:59 AM
snbundy's Avatar
Default Bike Won't Turn Over
I have a '01 SV650S that just won't turn over. I've tried two different batteries. Both are fully charged, and when I put them in the bike, it starts the bike. But if I let it sit for more than two days, the bike's lights will come on, but the engine won't catch. I am now hearing a rapid ticking when the ignition switch is engaged. I like to do my own work, and no, have not bought a manual yet, and will, but thought that I might get some ideas from people who may have had a similar experience. I've been told these bikes don't have starters, per se, or that maybe it's a relay switch in the starter- either one sound more logical? Are these easy-ish fixes for a novice mechanic?
Old Sep 27, 2008 | 12:34 AM
BassCliff's Avatar
Default RE: Bike Won't Turn Over
Hi Mr. snbundy,
Start here:
http://www.thegsresources.com/garage/gs_statorfacts.htm
...and see if this helps you get a handle on your charging system.
Are you saying that if you put in a new, known good, fully charged battery, the bike will drain it by sitting for a couple of days? Are you sure the batteries you are using are good?
Thank you for your indulgence
BassCliff
mikerm250
Sep 17, 2010 02:29 AM
robertmichaels
Aug 3, 2010 11:35 PM
robertmichaels
Aug 3, 2010 11:31 PM
Greenbass86
May 25, 2009 12:46 PM
JOEJAVA68
2
Sep 24, 2007 03:04 PM
