Fuel problems
Hello I have a 2008 m50 . Bike is not getting fuel the FI light stayed on steady for awhile now it doesn't come on when key is turned on . I have checked all fuses applied 12v to fuel relay and pump both work . Bike turns over but wont fire unless starting fluid is sprayed in intake. I get power to fuses and relay but not at fuel pump plug. Would really appreciate any suggestions thx
Fuel pump
Hello, I've seen several videos on you tube, and one guy pulled out the fuel pump assembly from gas tank and found some items came loose from the pump and some dropped into the gas tank. I hope this help.
Originally Posted by C50 rider 06
(Post 19746)
Bad wiring
Hello, may I ask, where did you locate your bad wires?
| All times are GMT -5. The time now is 04:44 AM. |
