limp clutch lever before and after replacing clutch cable?
Old Oct 13, 2008 | 12:32 PM
deemoney's Avatar
Default limp clutch lever before and after replacing clutch cable?
clutch lever goes limp after downshifting. replaced clutch cable still no change still can't put bike in gear. what next?
Old Oct 16, 2008 | 01:38 AM
BassCliff's Avatar
Default RE: limp clutch lever before and after replacing clutch cable?
Hi Mr. deemonkey,
Not knowing what year or model bike, how many miles, or past history other than a replaced clutch cable, I would hazard to say that it's time to take apart your clutch, check the steels and fibers for wear, replace if necessary. Also check the springs and replace if necessary. Then again, you might just need to adjust your clutch cable. It's hard to say, not very much information. What does your shop manual say?
BassCliff
esldomino
Apr 21, 2015 01:48 AM
POMO Biker
Dec 24, 2007 12:33 PM
swifter
Oct 6, 2007 02:54 PM
bigwatts
Aug 14, 2007 05:12 AM
dye2nyght
Jun 29, 2005 03:44 AM
