low beam out?
let me start and say yes I was an IDIOT.... Now that is over with.
I am putting lights on my C-50 green lights on a black and grey C-50.. Looks very nice. Now I was told to tie into the headlamp so I didnt need a switch. So I did right into the lowbeam side of the lamp. I was doing a test to see how the light looked with out protecting the splice and I grounded out. OUCH.. dont try this at home. My lowbeam dont work and the led I was checking out is done for. I checked out the 2 fuses under seat and both are good..?? So what should I check next? Please help Larry |
RE: low beam out?
hmm...have you tried running some stray wires, and putting power directly from the battery to the light? i am not sure where a resistor would be if the fuses are ok...im guessing that you changed the bulb already?
