Stator Issues????
Old 08-04-2019 | 09:13 AM
gregsc50's Avatar
Default Stator Issues????
I have a 2007 Suzuki Boulevard C50.
After charging the battery on a trickle charger the bike will only run for 20 minutes or so then it shuts off.
I was running it on the highway and each time it shut off was when I got of onto an exit ramp or just slow traffic. Not sure if this was a coincidence. The first time it happened I was able to push it to a p-lot and wait for my wife to come by with jumper cables. I put it on the jumper cables for about 20 minutes or so and then tried to make it back home. It ran fine until I hit some stop and go traffic and it shut down again. Hooked it back up to the jumpers cables and waited another 20 minutes then tried to finish getting home. It once again ran fine and even had to stop at a couple of traffic lights and it did not shut-off and I made it home. The last leg where I made it home was only a few miles.
I replaced the rectifier and had the battery checked out at local Advanced Auto and it was good.
I put my volt meter on the battery and got readings in the high 12's. I started the bike and and volt meter then read around 14. So it seems like it is getting a charge so why is it shutting off after about 20 minutes of riding? Thanks for the help.
Old 03-11-2021 | 09:29 AM
billdawg38730's Avatar
Default Stator
If it’s charging at 14 volts consistently then it ain’t the stator
Old 03-11-2021 | 09:39 AM
Default Stator
It would be nice if you could check the output while riding mine did that stopped at Walmart got a new battery installed and rode home about 50 miles .I got up next morning to ride and wouldn’t start checked battery and it was dead. Ordered a Ricks high output stator and voltage regulator installed and been good since but I also put a digital voltage readout on the handlebars so I can always see what the stator is doing also use an ohm meter and check regulator to see what if any resistance is there
gregsc50
08-09-2019 10:50 AM
gregsc50
08-03-2018 08:24 PM
Seif5034
06-12-2017 07:24 PM
Jdbucher35
02-28-2017 09:32 AM
Gsxrcrazy
09-27-2008 01:36 AM
