susuki 1400 intruder won't start
I was jumping my bike this spring to get it started and after it started i let it run for awhile then when i gave it gas it died and now i have no lights and it won't do anything. I checked my fuse box and everyhting is ok there. Don't know what else to check.
Originally Posted by Jim
(Post 3018)
Hey man, I can't for the life of me figure out how to post a thread on here. i see no 'new thread' button. But I see you have the same bike I have. What i need to know is; how do i access the fuse box? And if it is beneath the left or right cover, how do you take those off?
Originally Posted by Alotof Poutine
(Post 18975)
On further looking at the wiring diagram I think I will also try to connect to the red wire at the 25 A main fuse as well in my jumping. That should take care of it for sure. When I ran the starter, it made about 1/2 revolution and everything went dead, having a continuity breakdown |
Thanks for your reply. Yeah I was hoping I wouldn't have to remove the seats. I recently fixed a gas tank hose leak and had to remove the seats many times to finally fix the problem. Being a novice mechanic, it is all but too easy to not get it right the first time.
I think there are other fuses besides the main fuse box on the Intruder. Do you know? Like one by the battery. I started mine up today and it just kaputski on me. Hoping it was a derelict surcharge with an easily replaceable little fuse. |
Good news. Many are having trouble with the system going totally dead. I solved mine. There is a black wire that goes directly to ground from the battery BUT the one that feeds the systems is a spur connected to it. It is black and white. I suspect I pulled it apart removing/replacing the rear carb.
I accessed one of the B/W connections at the tail light in the rubber thing behind the big rubber box under the seat.I jumpered from the tail light feed to engine ground and IT IS ALIVE, ALIVE ! Now waiting for the battery to charge. Then I can see if cleaning the rear idle jet solved my original problem. If I canīt access the ground socket without disassembling the scoot, will run an auxilleary to ground from a B/W wire |
Fixed it
So I am glad to see you fixed yours and I am assuming it is all good now since you haven't left anymore messages.
As for me, twas but a scratch...a ground wire terminal riiiiight at the battery terminal because when I changed that battery last year I did not tighten it enough. Suzuki did not make it easy to do so as the battery has to dangle 1/3rd of the way down in order to just barely be able to squeeze a tool to tighten. Now....I wonder f this is why my odometer light and my rear brake light stopped working, being exposed to sudden disconnections from the battery? |
