richh |
04-04-2010 07:12 PM |
what frames fit
I recently purchased a 2000 gsxr 600 that was wrecked. Plastic isn't tooo bad, tail is shot along with frame being bent. My question is if i get a frame from a 02 what will fit. Big concern is that all the running gear along with forks and swingarm fitting. Don't mind getting new plastic, but if i could use them i would for now. Also is the tail secion of the frame interchangable from the 99 chassis to the 02 chassis. Thanks for the help. Also i have access to an aluminum welder, so if i had to cut and weld a little it isn't a big deal.
