Hey all Newbie here,need help or manual for 01 rm 250
So I just picked up this '01 rm 250 ,clutch cover is off,supposedly to replace leaking gaskets,clutch is missing 3 bolts and has one with bolt head snapped off shank of bolt,I plan to drill it out and replace,not sure of the torque required for install.
can anyone help? Thank you for reading. Paul |
Originally Posted by notjoe
(Post 8438)
newb /thanks you for help
Thank you wmatters,I actually picked up manual as I began to notice more and more 'important' looking parts in bucket guy gave me with bike.also found,lastnight,stripped treads on main gear shaft,picked up 10mmx1.25 tap,hope it's the right one,based it on two bolts from aforementioned 'bucket-of-parts' that looked as if they might have once fit shaft.
will keep you posted on progress. thanks again, Paul |
Originally Posted by mwatters
(Post 8445)
i don't konw the exact torque required, sorry! Did you check with your local suzuki dealership? they might be able to help. good luck and let us know how it goes!
| All times are GMT -5. The time now is 07:44 AM. |
