SF Help & Suggestion Center Need help with SF? Ask. Have a suggestion to better SF? Tell us here.
Need help/advice on TS100 rebuild for my Dad
Old 07-10-2009, 03:38 PM
jeff1122's Avatar
Default Need help/advice on TS100 rebuild for my Dad
I'm restoring a 1978 Suzuki TS100 for my dad as a surprise (it was his as a kid). I do not have a '78 manual, I only have a 1979-1984 manual, nor do I have a parts guide.
Problem: I bought an OEM oversize piston (1.0 mm oversize) on ebay and had the cylinder bored to that piston. The piston didn't come with rings so I went to my local suzuki shop and they actually had some rings in stock, but they couldn't confirm that the rings were the actual fit for the 2nd oversize pistion (aka....not able to reference part numbers for a match). They simply put the rings on the piston and acted like they "should work".
This is my first rebuild and I don't want to make a mistake with these piston rings, does anyone have a source that I could use to confirm part number of rings to match 2nd oversize piston. Or is there a way that I can confirm the size is an exact match without referencing original specs?
Old 07-21-2009, 12:48 AM
CocoChanels's Avatar
Should you tell you on a false way. __Данное сообщение автоматически сгенерировано и отправлено (с обходом всех антиспам защит) программой XRumer 5.09 Palladium. ЗДЕСЬ МОГЛА БЫ БЫТЬ ВАША РЕКЛАМА Сообщение выше, отправленное ботом с ником CocoChanels сгенерировано АВТОМАТИЧЕСКИ в соответствии с темой и содержимым топика, с помощью новой интеллектуальной системы, встроенной в XRumer 5.09 Palladium. Сам пользователь CocoChanels также зарегистрирован и активирован автоматически, без участия человека.
Old 08-12-2009, 08:42 AM
vapcrync's Avatar
what would happen if, for arguments sake, the husband that was presumed dead came knocking on the door with a policeman claiming he was still alive, and that his wife had now committed adultery? а не подскажите, какой банер можно разместить на киношном сайте? интересует что-то типо юзербара онлайн игры Net-Assault
BazM109
07-06-2010 08:17 AM
Huntytonsen
04-03-2009 05:53 AM
vwdee
04-25-2008 09:16 AM
Leslies_XL7
02-07-2007 05:27 PM
Blackwater
12-14-2006 10:36 AM
Quick Reply: Need help/advice on TS100 rebuild for my Dad
