CD stuck inside and anyone has diagram how to replace the audio system? thanks thanks
Hi I just bought a 2003 Aerio sedan. However, I just found a disk is actually stuck inside and can't get out. Does anyone know how to remove the audio system (sth. like diagram)? I would like to replace it with a new one. thanks a lot. Also, the car has 57k on it when I bought it two days ago. Does anyone know if I should do some big maintaince work? like changing timing belt? Thanks. chunyip |
RE: CD stuck inside and anyone has diagram how to replace the audio system? thanks thanks
Change oils. such as Trany, engine, Power Steer, Brake, Tire rotation, have brakes check Basic stuff nothing big you might need to replace sep. belt.
| All times are GMT -5. The time now is 09:34 AM. |
