Strut Sources and Engine Pinging
05 Aerio SX. I can't seem to find aftermarket struts. I was interested in something better than stock. Does anyone out there know of any source other than the dealership?
Has anyone had trouble with a light throttle ping? It happens with regular or plus but with super it seems ok. Problem is super is too damn expensive on an economy car.
#6
RE: Strut Sources and Engine Pinging
Yeah I had that issue too, just change the sparks plugs and wires you should be good. I also recommend lubing your sway bar and shocks that improves my ride all the time. I live in NM dry out here and cold I lube these parts every oil change. Go to PepBoys and they have some shocks and struts for our Aerio
#8
I can't help much with the aftermarket struts.
The pinging at light throttle can be a couple of different things. The first thing to check is the ignition timing. Unfortunately, to do this precisely requires some fairly specialized tools. You need a Suzuki scan tool (Tech-2), and a timing light that works on distributorless coil-over-plug ignition systems. I'm not sure if any aftermarket scan tools can set the system into "fixed spark mode" to set the timing.
Timing can be adjusted at the cam position sensor. The procedure in the service manual calls for putting the PCM into "Fixed spark" mode, which locks the timing to a fixed setting, and setting the timing to 5 degrees BTDC +/- 1 degree. To adjust, loosen the bolts on the cam position sensor slightly and rotate it. It works just like an old fashioned distributor.
There are several other things that can cause detonation and spark knock. An EGR system problem can cause pinging, especially at light throttle.
Anything that causes a lean condition can also lead to pinging. Vacuum leaks, low fuel pressure, faulty MAF sensor or faulty MAP sensor, among many other things can cause a lean condition.
#9
You get what you pay for. Watch your mileage between the premium and cheaper fuels! If your engine runs better on premium, try switching brands with mid octance fuels and see if it still pings. I continue to use Chevron without any problems.
#10
ORIGINAL: lomita
