Any New TSB's
Any New TSB's
I have been looking for Recalls every week since I bought my car to see if there are any recall of some sort and I have found nothing. Just customer issues with their own cars. I'm an active user in www.aeriostyle.com these are the ones I've seen at this site only so far:
TS 01 02274 SLOW AND/OR INCOMPLETE RETRACTION OF SEAT BELTS
TS 02 06284 LEFT DRIVE SHAFT POPS OUT OF FINAL DRIVE M/T
TS 03 06304 ALTERNATOR REPLACEMENT More power
TS 02 05074 FRONT BRAKE PADS New #s for'04
TS 03 06253 SAFETY RECALL, WINDSHIELD MOUNTING, POOR ADHESION.
TS 02 06203 WINDSHIELD WASHER HOSE UPDATED PART NUMBER
TS 01 12112 METALLIC CLACKING/CLICKING NOISE WHEN APPLYING BRAKES
TS 02 03273 POPPING NOISE ON SLIGHT TURNS
TS 01 01303 ELECTRICAL NOISE ON A.M. STATIONS
TS 02 12112 ENGINE TICK NOISE Air in Lifters
TS 02 09112 PROGRAMMABLE KEYLESS ENTRY SYSTEM Dead fobs
TS 01 02103 SELECTION METHOD OF THE STANDARD SIZE CONNECTING ROD BEARING Several TSBs about the same topic
TS 02 01074 CORRECT COOLANT USAGE Ethylene Glycol Phosphate for Aerio
I'm not to sure how it was but I think TS-means Troblemshooting then on # next is your year model then suzuki lot # then the problem noted. If you have an 2004 Aerio SX or aerio in general post here on any new TSB's that you have incourted this info isn't free for some reason Suzuki not proactive on give out this info. you have to go to suzuki.com and purchase this info if your a dealer you can get this info free. Anyway, like I said if you have an issue and therefore your Suzuki rep makes an TSB for that issue try to post it here
RE: Any New TSB's
I had an Ford Escort SE 1999 this is my story on why I made this post. I made a Hugh move in 2003 From Bronx, New York to ABQ, NM (which is Albuequerque, New Mexico) I had to buy a car out here they to that their transportation (e.g. Buses, Trans, Cab) is nonexisten. Every 90 mins a bus only in the Central region of ABQ. Well I bought an 1999 Ford escort SE wagon ran good for six months til it dead. I drove the car the way is was surposed to and it crap out I bought the car used from the Ford dealership. It had about 80k on it bought it cheap 2k not bad I said for an 99 when the engine died it had 120k. Yes, I put 40k on the car in six months their a lot of driving to get anywere here I'm still amazed myself! I check for recall after recall the 1999 had a recall on it's mau trans to be fully replace not the auto so I was SOL. The Ford dealership had my car for a month without looking at it and they never gave me a loaner until I started Bitching then I had their new 2003 Focus and it was doing the same thing my 99 escort was doing stalling out at 35 mph on the damn HWY. Had their car for another month then they started to look at my car like what the F@(%. Service manager was fired and they didn't know they had one of their cars missing and my car was in their lot. They were going to junk my car and report the car I was in stolen LOL. The new service manager took care of my car issue claims that the 2nd and 4th cyc where not working and that was why my engine wasn't working. they can fix it for 5k for a new engine without labor it'll cost me 7k once there done and they'll give me a 30k mile warrenty and two free oil changes if I go with them. I told them to eat it reported the dealership to BBB Don Chamlers Ford in ABQ. So the point was I bought american only cars til this happen to me and now I'm a very happy owner of an Suzuki Aerio SX 2004. I'm an commerical Realtor and sold the property next to Don Chamler Ford to a Perfection Honda dealership just a year ago now the dealership is hurting for business they have about an 4 acre lot full of 2002/2005 cars that still have not sold.
RE: Any New TSB's
Here's the basic info that I got for free from suzukipitstop.com I'll make it all prettier later but for now it should be enough I figure.
Aerio 04 01315 Correct Torque Converter Bolts 2002-2006 1/31/2005 General 02 12164R Programmable Keyless Entry System 2001-2002 12/16/2004
Aerio 06 12144 Driver and/or Passenger Side Mirror Loose 2002-2004 12/14/2004
General 05 11094 Service Manual Update for DTC P0420 and/or (P0430 V6) Inspection and Troubleshooting 1996-2005 11/9/2004
General 04 10214 VIN# Registration After ECM Replacement 2005-2006 10/22/2004
Aerio 05 10124 Service Manual Update Headlight installation 2002-2004 10/12/2004
Aerio 03 07084 Service Manual Correction Tightening Torque of Gear Shift Interlock Bolt 2004-2004 7/8/2004
Aerio 01 07084 Bevel Pinion Mounting Distance (AWD) All Years 7/8/2004
Aerio 03 06304 Alternator Replacement 2002-2004 6/30/2004
Aerio 02 06284 Left Drive Shaft Pops Out 2002-2004 6/28/2004
Aerio 04 05174 Instrument Cluster Bulb Replacement 2002-2004 5/17/2004
Aerio 02 05074 Aerio Front Brake Pads 2002-2004 5/7/2004
Aerio 01 032904 Service Manual Update Manual Transmission Assembly Procedure 2002-2003 3/29/2004
Aerio 01 02274 Slow and/ or Incomplete Retraction of Seat Belts All Years 2/27/2004
Aerio 02 01074 Correct Coolant Usage 1986-2004 1/7/2004
Aerio 01 10173R Tech 2 PCMCIA Card Re-Flash Update All Years 9/30/2003
Aerio 02 07113 Service Manual Update - EVAP Inspection Procedure 2002-2003 7/11/2003
Aerio 03 06253 Safety Recall Campaign; EC FM VSS 212 Windshield Mounting 2002-2003 6/25/2003
Aerio 02 06203 Windshield Washer Hose Updated Part Number 2002-2003 6/20/2003
General 03 05073 Rear Main Oil Seal Installation Tools 1999-2003 5/7/2003
Aerio 02 03273 Popping Noise on Slight Turns 2002-2003 3/27/2003
Aerio 01 02103 Service Manual Update - Rod Bearing 2002-2003 2/10/2003
Aerio 01 02033 Service Manual Update 4WD Alignment Specifications 2003-2003 2/3/2003
Aerio 01 013003 Electrical Noise on AM Stations 2002-2003
Aerio 01 12192R Revised Metallic Clacking/Clicking Noise When Applying Brakes 2002-2003 12/19/2002
General 02 12112 Engine Tick Noise 1999-2003 12/11/2002
General 01 02252 Technical Service Bulletin System Revision All Years 2/25/2002
General 10-1 04210 Air Bag On/Off Switch Installation Instructions 1995-2003 4/21/2000
RE: Any New TSB's
Yeah, we know, Ford sucks...now never mention it again.
In the world of ford recalls are common...but these arent recalls. These are common problems that CAN occur, and if it does these numbers will be helpful for you to communicate with your service man. And these numbers, I believe, lead him to the technical info he needs to fix the problem.
Very good of you to put them all in one place...thank you!
jnnvrwoood
02-22-2007 12:39 AM
PartsMan
01-20-2007 05:06 PM
