2005 c50 idle issues
Peeps, good day to everyone. I own a 2005 C50 Blvd for a bit over a year now. At the end of 2023, I was having the bike running rough. I started with replacing the spark plugs & the air filter. When same symptoms were still there, replaced the fuel injectors (not SUZUKI brand) with OEM ones. The issue after that I was dealing with she was not staying on low idle & she would shut-off on full stop. I messed around with the small screw to adjust the idle but never got it to be perfecdt. Now she will not turn off at full stops but will accelerate on her own & will not deaccelerate back to normal idle. It's like when a car on cold start will idle high until it reaches normal operating temperature. My C50 will not run on normal idle & idle high rev's. Hopefully I am explaining myself properly. TIA
