intruder not tracking straight
Old Nov 15, 2005 | 01:28 PM
jc's Avatar
jc
Default intruder not tracking straight
I have a 93 Suzuki Intruder 800 that seems to track to the left when I take my hands off the handle bars. It has new tires front and rear tires that were installed by a dealer and the forks and handle bars seem to be straight. Can anyone give me an idea of what is going on?
Old Nov 16, 2005 | 03:47 PM
Patrick's Avatar
Administrator
Default RE: intruder not tracking straight
this is a non-stop issue? sometimes tires arent made perfectly, and you get what is called "radial pull"...take it to the shop that installed the tires and ask about it..i dealt with it quite a bit while working on cars.
Old May 1, 2007 | 12:34 AM
Scarab92614's Avatar
Forks and handlebars may look straight but the frame could be tweaked. That might cause tracking problems. As for the tires that could also be a problem-take it to the shop and check and make sure the frame is straight and that your wheels are true and straight as well.
[align=left] [/align]
Old Oct 28, 2011 | 07:26 AM
irishdriven's Avatar
do you have saddle bags on it? if so is the weight even on both sides also make sure one side doesnt stick out farther than the other wind pressure could affect it
Old Oct 12, 2014 | 12:05 PM
ariana66's Avatar
The tires that could also be a problem-take it to the shop and check and make sure the frame is straight and that your wheels are true and straight as well.
jlcamp56@msn.com
Feb 25, 2009 11:01 AM
skylar.sutton
Oct 6, 2008 03:54 PM
viclioce
Mar 28, 2006 01:36 PM
