Replaced Clutch now Transmission Problems
I have a 2000 Suzuki Marauder 800 that was working fine except for a little clutch slipage. I reaplaced the clutch and it works great but now the transmission will not hardly shift, the shifter is very stift and you can ony get it to go into first, neutral, and second and it doesnt click. Please Help I Want To Ride!
Thanks Jairus |
Do you have a hydraulic clutch? If so, the clutch may require additional bleeding. It sounds like you still have air in the clutch line.
