-   Suzuki Cruisers (https://suzukiforum.com/forum/suzuki-cruisers-14/)
-   -   Suzuki Intruder 1400 (https://suzukiforum.com/forum/suzuki-cruisers-14/suzuki-intruder-1400-a-1155/)
svdiablo Oct 7, 2007 08:36 PM
I have a 1995 1400 Intruder
I have problem with front carb
I am not sure but one of the jet is plugged
i lose the scruew at the bottom of the carb
i can see fuel coming out if i spray carb cleaner
it runs good ,the anybody can tell me if the main jet
is visible from the top of the carb
Thanks Vito
trackfodder Jun 2, 2016 11:25 PM
Oil mystery
The 1991 VS1499GLP I am preparing has a problem and I am puzzled. I removed the oil filter and a little bit of dirty oil came out, less than a pint. The bike was sitting on a support to make it level and the front wheel was really high. I pulled the drain plug and nothing came out. I was going to install the battery anyhow so I jacked up the rear and put the old battery under the rear wheel, which made it level. STILL NO OIL came out. Here is the mystery---The oil on the dipstick is clean and appears full to the normal mark. ????
I have a raft bellows air pump. Tomorrow I will put a rubber stopper on the nozzle and put pressure on the dipstick hole and see what happens, and maybe on the drain hole. Ideas, guys?
trackfodder Jun 3, 2016 10:23 PM
Wheee !
WHEEEi I found a man that used to sell and service Suzukis. He is the checkout man at Peters ACE Hardware in Dewey OK. He told me the earlier ones (my 1991) have a drain plug at the rear of the tranny.
I pulled it and almost a gallon of pretty oil came out. The front plug I was told was the drain is just an attaching port to measure oil pressure. I refilled with 10W30 full synthetic. After a miserable time trying to attach the battery leads, I brought the battery home and secured the post nuts with Shoe Goo. The replacement clutch switch didn't have the lead attached, but I discovered the old one had the right-angle female spades I needed after I disassembled the carcass.
Billy Womack Aug 23, 2019 07:51 AM
Possible driveshaft issues
I took off from stop sign shifted to 2nd gear , engine kind of backfired . Sounds like rattling noise from driveshaft area , motor is ok no power to rear wheel. Is anyone familiar with this problem ?
