60A fuse question
60A fuse question
Hi all, some advice needed.[/align]There is a thick white wire coming off a 60A fuse in fuse box 1. That fuse box is the one that comes directly off the battery.The wirebypasses fuse box 2 and comes all the way to the fuse box below the steering wheel. What do you think about using that to power a small amp?
My amp is a 200watt infinity basslink. It has a 20A fuse on its battery input terminal suggesting it does not make a high demand on current like analog amps. What do you think?[/align]
