New Tires and Steering Wheel Vibration
Hye guys...I have an 08 GV Lux and just recently installed a set of Goodyear Assurnace Fuel Max tires on it. Prior to that I had the crappy Yokohamas that only last about 28000 miles.
Here is the issue...when I 1st purchased the vehicle I noticed a slight steering wheel vibration from 40-50 mph. Since the truck was due for new tires anyways i figured the new tires would rectify this problem!
Well it did but not 100% as I still get a slight steering wheel vibration from 40-45mph and then again (very slight) at around 70mph and goes away at 75. However, The vibration is less noticable/non existant in the morning when the tire pressure is still at 32psi and as the tires begins to warm up it becomes more noticable. Also if i don't accelerate very quickly from 40-45mph the vibration is pretty much non existant and if I am cornering at 40-45mph I do not notice the vibration.
Otherwise than that it runs perfectly smooth at other speeds with no vibration at all!
Should I have the tires re-balanced at a diffrent place or do I have an issues that stems beyond my new tires? I am VERY picky about my truck and I do love this lil tank and would like to know if this is something I can have fixed regardless if its wheel balancing or something else.
rodeovortex
06-20-2012 06:41 PM
