suzuki rm 125 1996 no compression on kickstart
hi
i brought a suzuki rm 125 just over 2 weeks a go last week end it just died when i was riding it and wouldnt start off the kick or bumping it, i have noticed theres no compression in the kick start does any body no wat the problem is thanks alot jim |
RE: suzuki rm 125 1996 no compression on kickstart
if there were no noises or if you didnt have it full throttle for a long period of time it sounds like you need to put a new ring in it to me no big deal its a normal 2 stroke thing but if you had it wide open for a while you probibly melted o hole in the piston take your plug out and check it for metal if there isnt any its prob just the ring.
ORIGINAL: codicur if there were no noises or if you didnt have it full throttle for a long period of time it sounds like you need to put a new ring in it to me no big deal its a normal 2 stroke thing but if you had it wide open for a while you probibly melted o hole in the piston take your plug out and check it for metal if there isnt any its prob just the ring. |
| All times are GMT -5. The time now is 06:08 AM. |
