89 rmx 250 carb problem
Hopefully someone can help me. I can usually figure stuff out, but this one has me beating my head against the wall. On my 89 RMX 250 I am having a problem where my carb is dumping fuel out the bowl overflow vent. I took everything apart and cleaned it thinking my needle valve was stuck. Didn't work. I took it apart again and checked the diagram in my maintainence book against the carb and everything is in place. Any ideas?
Thanks |
RE: 89 rmx 250 carb problem
Sounds like the float may be bad (filled with gas so it doesn't float).
Hope this helps. |
