Editing JVC GC-PX100 1080p AVCHD with FCP
Old 03-10-2013 | 09:19 PM
JhonBong's Avatar
Default Editing JVC GC-PX100 1080p AVCHD with FCP
The JVC GC-PX100 Full HD Everio Camcorder captures Full HD 1920 x 1080 video and up to 12 Mp still images. It can record Full HD video and 3 Mp still images simultaneously as well. It features an SD / SDHC / SDXC memory card slot, a back-illuminated 1/2.3" 12.8 Mp CMOS image sensor, and a wide angle F1.2 Super Bright Lens. The high-quality lens supports 10x optical zoom, 16x Dynamic zoom, and 200x digital zoom. The camcorder has a FALCONBRID engine, x.v. Color, and a 3" touch panel LCD for easy recording and instant playback.
Have you got the camera? If you have got one and shot some 1080 60p videos with it, you will find the clisp are not supported well by Mac OS X computer. Because the 1080 60p is not a standard format for playing and editing. It is unsupported by QuickTime, iMovie, FCE, Final Cut Pro 7, ect softwares. Then how to make it comfortable for Mac? Here we take iMovie as an example.
First, you need to download a top AVCHD to iMovie Converter to transcode the 1080 60p AVCHD to iMovie's vide format. Then follow the below are the steps for you to convert your JVC GC-PX100 AVCHD files to FCP 7 for editing.
Step 1: Install the best JVC GC-PX100 MTS converter, then input the recordings to the it.
Tips:
1. You can imput several files to the programs one time, and if necessary, you can use the function "Merge into one"
2. Click "Browse" on the buttom of the main interface to decide the place in which save your converted video.
Step 2: Click the Output bar, you can find that there are many output format there. For FCP 7/X, all these five output formats are supported. Apple ProRes 422 is the first choice certainly.
Step 3: Adjust audio and video parameters in Profile Settings. You can change the default codec, bit rate, frame rate, sample rate and audio channel according to your needs and optimize the output file quality.
Tip: Recommend: Video Size:1920*1080 & Frame Rate:30 fps(NTSC) or 25fps(PAL)
Step 4: Tap the Green Arrow button on the main interface to start transcoding JVC GC-PX100 1080p 60p video to ProRes for editing in FCP 7/X.
After the conversion(with 100% accomplishment), you just need to click the "Open" button on the main interface to find your converted file. That is to say you can edit your JVC GC-PX100 recordings in FCP easily and effortlessly.
Related guides:
Make JVC GZ-E100/JVC GZ-E300 AVCHD 1080p videos editable in FCP X
Convert/Transcode JVC Everio MOD to Apple ProRes for FCP on Mac
Convert JVC GS-TD1 AVCHD MTS/M2TS to Apple ProRes for editing in Final Cut Pro
Convert/Merge/Transfer JVC Everio GZ-MS120 MOD to Toshiba Thrive
Free download JVC GZ-HD6 TOD to FCP Converter- Convert/Copy/Import JVC GZ-HD6 1080/60p TOD to FCP
JhonBong
03-20-2013 12:25 AM
JhonBong
03-05-2013 09:28 PM
JhonBong
02-27-2013 08:45 PM
JhonBong
01-15-2013 12:45 AM
