coolant leak
Hi !
Every day something new , Yesterday I found that XL7 is losing coolant, radiator is full, botle is almost empty, temperature is in the midle ,doesn't rise up I can't find where is leak because air from fans move coolant everywhere .When car is not moving coolant drops on passenger side Like I said couple weeks ago when mechanic replaced tensioners , watter pump was replaced too. I can't see any leak around water pump, oil level is good , only thing I am woried is on cap where you add oil is white residue.Mybe because I added lucas oil to quiet lifter noise. Thank you again for all your help |
