C50 case guards question
Old Oct 8, 2006 | 07:08 PM
C50WI's Avatar
Default C50 case guards question
Hey guys. I just got a pair of case guards off of ebay the other day. Seems to possibly be a problem with the brake pedal hitting the right side guard. It didnt come with any spacers or anything. Am I supposed to have spacers on the right side or what? anyone else had this problem? The left side will fit perfect. I have a '05 C50. Thanks for any replies.
Nick
Old Oct 9, 2006 | 10:39 PM
Edmo's Avatar
Default RE: C50 case guards question
By case guards, do you mean engine guard bars? These are the ones which mount on the left/right front sides of the frame and allow you to mount highway peg...
Edmo
Old Oct 10, 2006 | 07:39 PM
C50WI's Avatar
yes, engine case guards, I think I may have figured it out though. the bottom mounts of the bars are supposed to be mounted on the inside of the frame, rather than the outside....
Old Nov 11, 2007 | 08:11 PM
smcleo1982's Avatar
If you are talking about the Suzuki engine guards they do come with 2 spacers but you put them on the top bolts. I would suggest that if your brake pedal hits them that you adjust the brake pedal back a little bit, i will have to look at mine and see how close they come but i have the suzuki ones and they do not hit.
Old Feb 21, 2008 | 10:48 AM
jkenn3's Avatar
Greetings...If I'm not mistaken the case guards for 01-04's and 05-08's are slightly different and not interchangeable.
Hope this helps
jkenn3
Old Feb 26, 2008 | 08:20 PM
  #6
C50WI's Avatar
yes that does help. I actually ended up selling the ones I had. Plus it didnt come with any hardware. I'll make sure next time what years the guards fit. Thanks a million
enigmanamaly
Mar 5, 2013 03:00 AM
nicecaty
Dec 16, 2010 10:04 PM
mountaintrout
Jan 29, 2009 12:43 PM
mountaintrout
Jan 28, 2009 12:56 PM
stwischmeyer
Mar 12, 2008 06:47 PM
