Loud Noise
Old May 26, 2010 | 10:37 AM
Imoverit's Avatar
Exclamation Loud Noise
I want to make my C50 bark so i'm thinking of taking the stock mufflers off and putting on 2.5 inch pipe. Does anyone know if the fuel injection system will automaticly make any fuel adjustments ?
BJ
Old May 29, 2010 | 03:20 AM
Imoverit's Avatar
Anyone ???
Old Jun 6, 2010 | 03:52 AM
Imoverit's Avatar
Exclamation
No one has a c50 in here that has modified there pipes ???
Old Jun 10, 2010 | 05:53 PM
dee-skillz's Avatar
i have a 2006 c50 with cobra slash cuts that i debaffled and as far as i could tell the fuel injection system did not make any automatic adjustments...after debaffling i purchased a Fi2000 fuel injection processor which has hi, mid, and low adjustments on it and it has been killer!!! im planning on buying hard krome exhaust with removable baffles so now i can choose to run it straight piped or not....and i can adjust it for either setting...
Old Jun 14, 2010 | 05:58 AM
Imoverit's Avatar
Thanks Dee.
BJ
Old Jun 14, 2010 | 06:13 AM
  #6
Imoverit's Avatar
Its so confusing as everyone has a different view.
Old Jun 16, 2010 | 05:37 PM
  #7
dee-skillz's Avatar
no prob!!!
Old Jul 7, 2010 | 02:29 AM
  #8
briankmizell's Avatar
how much difference did the fi2000 make, what did you notice the most.
HP gain, torque, What rpm did it make the most difference.
Old Jul 8, 2010 | 05:37 AM
  #9
dee-skillz's Avatar
a little gain in torque....mostly on the mid to high end, but mostly it eliminated back firing and a idle problems. If you choose to mod your exhaust, along with the Fi2000 be sure to at least get a k&n high flow air filter as it will compliment you fuel processor in performance and get rid of that nasty lurching that happens when you let off your clutch in low rpms on you c50
Old Jul 9, 2010 | 02:51 AM
  #10
Mine has vance & hinse pipes on it and the factory air filter.
This lurching you talk about, can you explain what you mean by lurching.
MDM50
2
Dec 4, 2013 02:20 AM
powernerd
Mar 6, 2011 02:12 PM
suzukitech
Oct 19, 2008 12:52 AM
yahoo1z
Nov 11, 2006 09:36 PM
glazguy
Sep 24, 2006 10:48 PM
