Suzuki Engine Sound, are they all loud?
Old Jul 21, 2005 | 04:44 AM
yahoo1z's Avatar
Default Suzuki Engine Sound, are they all loud?
Hi, I recently bought a 2001 Grand Vitara, the engine is very loud, when i rev the engine above 5000rpm in neutral, it sounded like a truck, is it normal? is all suzuki engine loud?
thanks for any opinions.
Old Jul 22, 2005 | 02:09 PM
Patrick's Avatar
Administrator
Default RE: Suzuki Engine Sound, are they all loud?
does the sound seem to be coming from under the hood, or under the car?
Old Aug 2, 2005 | 10:58 PM
ShortBuSX's Avatar
Ive read this post in couple forums...have you even bothered to get down on the ground and look to see if there has been any work on the exhaust? It should be quite obvious if they had...if your still concerned take it to a muffler shop...but realize, you are driving a truck!
Old Aug 8, 2005 | 08:18 PM
Patrick's Avatar
Administrator
i knwo that some of these had problems with the flex piece falling apart, especially if it has high mileage
Old Nov 11, 2006 | 09:36 PM
sidewinder's Avatar
Hi, my name is Grumpy and ShortBusx hates me because I am going to make his car blow up using bad karma voodoo from My SX.
Now that's finished: Yahoo: Firstly, Don't rev your car to 5 grand at idle. Not good for motor. My wifes 02 vitara had the bolts rust out and break that hold the cat outlet to the muffler inlet. They have spring loading - the "flex" aspect that others have mentioned. The coupling gasket there will be failed also. Check this first. Suzuki engines can be noisey if they are failing, but should be quiet otherwise. Shots' car is STILL running so use his advice on motor oil and filters, etc. I obviously made bad choices - or played my CD player too much without wearing my tin foil hat
Rock56Star
Apr 18, 2013 11:29 AM
powernerd
Mar 6, 2011 02:12 PM
Dean Sweeney
Jan 21, 2011 06:20 PM
tuffluck
May 1, 2008 09:03 PM
yahoo1z
Sep 15, 2007 12:01 PM
