Anyone ever replaced front turn signals on m50?
I have an 06 Boulevard M50 and bought a set of turn signals. I changed the rear ones out with no problems. Now I can't figure out how to get the fronts out to put the new ones on. I have the headlight taken apart to access the wires and there's 3 wires for each turn signal, the rear signals only consisted of 2 wires... Please help me somebody!!!
Front signals
Originally Posted by Matt617
(Post 10275)
Front ones have three wires because two are used by the relay for blinking function and the other wire keeps the lights always on as drive lights. The rear had two wires because those are blinkers only and don't have an always ON feature.
If your aftermarket lights have only two wires, then they will only work as blinkers and won't stay on like the originals..... that is if you wire them correctly. I believe you want them to function as blinkers, and not drive lights. |
