Anyone ever replaced front turn signals on m50?
Old Jun 3, 2013 | 04:41 PM
Matt617's Avatar
Default Anyone ever replaced front turn signals on m50?
I have an 06 Boulevard M50 and bought a set of turn signals. I changed the rear ones out with no problems. Now I can't figure out how to get the fronts out to put the new ones on. I have the headlight taken apart to access the wires and there's 3 wires for each turn signal, the rear signals only consisted of 2 wires... Please help me somebody!!!
Old Mar 10, 2021 | 07:33 PM
billdawg38730's Avatar
Default Front signals
The front will have one black and one black and white and one gray .The gray splices to orange, then black to black,then black white to black white black white being the ground this is front left for the front right black/to bluish. green then gray to orange the black white to black white
Old Apr 13, 2021 | 01:25 PM
MJ-Sid's Avatar
Front ones have three wires because two are used by the relay for blinking function and the other wire keeps the lights always on as drive lights. The rear had two wires because those are blinkers only and don't have an always ON feature.
If your aftermarket lights have only two wires, then they will only work as blinkers and won't stay on like the originals..... that is if you wire them correctly. I believe you want them to function as blinkers, and not drive lights.
perk_dp
Mar 10, 2021 07:54 PM
joeburris
Jan 1, 2021 01:54 PM
james75
Jun 10, 2018 07:15 PM
gzzzr
Aug 15, 2008 04:29 PM
suzukim50
May 3, 2007 08:01 PM
