Better headlight (visibility)
Old Nov 12, 2007 | 03:12 PM
susuki_s83's Avatar
Default Better headlight (visibility)
I just changed my head lamp from stock Philips H4 60/55W to Silverstart (Sylvania) H4 ST. This is way brighter. Changing it was a little painful, getting the screws back in to hold the assembly together. I recommend pointing the light @ a marked spot on the wall, prior to removal, so when you put it all back together, you can re-site it. Also, make sure you do not touch the glass of the bulb - it will cause it to burn up quicker.
This is all about making you safer by making you more visible to cars during daytime riding.
Old Dec 8, 2007 | 12:46 AM
Scarab92614's Avatar
Default RE: Better headlight (visibility)
ur using the same type of bulb though and i was pretty sure an H4 has the same wattage across the board-but if it is different and as long as it is legal then i guess it would be ok.
alex51
Jan 21, 2014 12:46 PM
martin cooper
V-Strom 1000, V-Strom 650
2
Jul 19, 2010 10:02 PM
susuki_s83
Nov 28, 2007 07:07 PM
rufus5790
Sep 30, 2006 08:35 PM
