2021 Suzuki Swift odometer calibration by Xtool X100 Pad2
Old Jan 1, 2023 | 09:25 AM
Daysi23mm's Avatar
Default 2021 Suzuki Swift odometer calibration by Xtool X100 Pad2
Xtool X100 Pad2 is supported to successfully perform odometer calibration for a Suzuki Swift 2021 RH850 VDO via OBD. It’s a very easy and quick job in 1 minute.
Follow the steps below to learn how to do it.
The mileage on dashboard is 2910km now.
Connect X100 Pad2 with OBD, press
Instrument cluster >> Suzuki >> Swift >> 2020- >> RH850 VDO >> Mileage adjustment
Please input the file name to save it:
The file is saved the original vehicle data, not to be overwritten.
The EEPROM data is successfully backed up.
Press “OK”.
Enter the new mileage:2995km.
Repaired successfully.
Amazing speed!
The dashboard changed almost at once to 2995 km.
Done!
Old Feb 8, 2023 | 08:01 AM
Daysi23mm's Avatar
Xtool X100 PAD2 is a good choise! There is not bad tool. It can do new nissan cars with 20 pin code in few second.
Daysi23mm
Oct 26, 2022 08:04 AM
edidgeCasyday
Jan 30, 2011 06:15 AM
skylinenet
Jan 25, 2011 08:52 PM
skylinenet
Jan 13, 2011 11:30 AM
BE11WOOD
Feb 9, 2010 03:09 AM
