2024 WOYO CTB008 BMW Motorcycle Diagnostic scanner BMW Bike Tester
Old May 19, 2024 | 11:37 PM
Daysi23mm's Avatar
Default 2024 WOYO CTB008 BMW Motorcycle Diagnostic scanner BMW Bike Tester
If your motorcycle model is after 2017, you don't need to purchase with the OBD2 to 10pin cable.
But if your motorcycle model is before 2017, please purchase with the OBD2 to 10pin adapter cable.
Read and Clean Code by OBD2 or 10Pin connector
This CTB008 model is compatible with all newer EU-4 compliant BMW motorcycles with OBD-II connector ports.In addition, when used in conjunction with the female OBD-II adaptor cable this product is also backward compatible and supports ALL the previous models of BMW motorcycles that have round 10-pin diagnostic connectors.Bluetooth connection let you easy to connect outside.
Daysi23mm
May 29, 2024 02:08 AM
Daysi23mm
Aug 24, 2023 02:09 AM
Daysi23mm
Mar 6, 2021 10:22 AM
arah9227
Feb 16, 2013 12:54 AM
Danae Tang
Jun 7, 2012 05:01 AM
